Disables an RSVP-TE LSP.
| lsp_name | Specifies the LSP within the switch to be disabled. |
| all | Disables all RSVP-TE configured LSPs. |
Enabled.
This command disables an RSVP-TE LSP. When an RSVP-TE LSP is disabled, the switch terminates the LSP by signaling the destination by sending a PATH_TEAR message. If there are other LSPs configured to the same destination, traffic may continue to be transmitted to the destination over another LSP. Disabling an LSP does not otherwise change its configuration.
The following command disables the LSP named lsp598:
disable mpls rsvp-te lsp lsp598
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
